Neil from 3:34 pm.
Jim (that is me) has to do handsprings because he is not using a Morelli shape; the USS Akron is the basic shape with only some tweaks according to Morelli's guiding principles.
The Aptera does not have to do handsprings because it is almost exactly a Morelli shape,except for the rear wheel which is on centerline so it might not cause too much of a problem. However, the Aptera is plenty long, but still has no rear seat, since the Morelli shape requires the underside curve that cuts into where the floor would need to be.
