Originally Posted by bennelson
 The second chart is a cumulative energy use per hour. Since it is set to hourly, and measured in KWH, basically that's that average watts used that hour. Note that the chart maxes out at not much over a KWH.
You mean average Kilowatts used that hour, right?
Does your dishwasher really use that much power? It must be electrically pre-heating the water and using lots of heat in the drying cycle as well.
I bet you're going to try to reduce that 89W fridge off, vacant house figure. Hmm, I wonder how much power my house uses while I'm away.
