Old 09-05-2010, 12:18 AM   #5 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
calculated load and VE
yes
calculated load with volumetric efficiency
will show that the SNAKE OIL does not "improve" anything .
MAF values with fuel trim can show similar results or not,
as i think some cylinders will be lean and some rich , using that JUNK ,
total fuel trims will not change much MAF will be higher .
http://www.autoservicetech.com/vecalculator.html
but calculated load with VE under the same conditions with and without the HOAX installed would be easier to see
i would use the ATS Escan VE test screen , but the link above will be good for an
A - B comparison
imho
Last edited by mwebb; 09-05-2010 at 12:21 AM.. Reason: http://www.autoservicetech.com/vecalculator.html
