Old 09-06-2010, 12:16 AM   #143 (permalink)
shorty_boy
shorty_boy's Avatar
Got'cha on the vacuum lines.
As far as the brakes are concerned, I am about to put on rear disc brakes (from an SI) and then change the master cylinder to increase brake pressure. I am afraid to change out the front brakes because the hf has specific axles and spline count.
How are you using DX discs? I thought that they share the same hub as the SI and that the axles are the same as the Si axles, which don't fit into HF trans.
1989 CRX HF "... and i will call her betsie and betsie will be mine!"
Resurrected 1/15/2012.
Shorty's Mods, Swaps, and Reviews.
