Old 09-05-2010, 11:24 PM   #14 (permalink)
Zerohour
Zerohour's Avatar
Pooparu - '01 Subaru Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Chevy Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '11 Mini Cooper
90 day: 37.63 mpg (US)
Gramps - '95 Subaru Legacy Postal
90 day: 23.18 mpg (US)
Very Nice Olympiads. I Have seen these before. Just never realized what they were. Out old 86 ranger had one. Never knew it was controlled by wax. Pretty neat idea. I still might go with the door actuator. It seems like cutting apart an air box intake from a junk yard might not be worth it. I'm already going to need a custom inlet and tubing, modifying an oval shape inlet would probably make it more complicated.
Quick quest for you all, a scan gauge gives air intake temperature correct? I've been thinking about trying to rig up a circle for this as well. Maybe utilize a water temp sensor in the heat conducting pipe. Or using something else like an air temp sensor hooked up to a voltmeter. I've got a few ideas running around, and honestly I think the watertemp sensor in the intake pipe would give me a clue as to what temp is being pulled off the exhaust.
