4130 Products - Step-By-Step
drive it home with the ignition bits apart. use a jumper to the fuel cutoff solenoid and bump start it if necessary. get fancy after you get home.
edit: but get it, $200 is a no-brainer if you have room for such a project and a path to a clear title.
