Old 09-07-2010, 03:47 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
do you know what the signal to the injectors looks like? i.e. is it a constant 12 volts applied to open the injectors, or is it pwm and/or peak and hold? If it is constant 12 volts then you can just change the injtrig in the menu to tell it to look for a positive signal.
The Following User Says Thank You to dcb For This Useful Post:
Bristol603 (09-07-2010)
