Frank Lee,
Right you are, except the burden is not as bad as you seem to think. If the articulated form is used, the wheel system has a very strong stabilizing action, but the detail of that is a little difficult to see from the first picture. If we just use low weight to handle stabilization and use a four wheel system, that will work also, though in that case the wheel base will need to be widened some.
