Did not bring the car home, guy said the tires would be round, one was not. Gonna try tomorrow. Used the blunt force applied to a small area to destroy the key part. Then snipped the starter wire, and stripped a bit of the hot wire insulation. turned the guts to disengage the lockout, and stuck it in 3rd and it moved under it's own power.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
