I think that sounds right. Unless you can manipulate the wave form to be fatter and less sine wave shaped so you get more area under the curve. I have no idea if that can be done...sounds like the 300v mosfets would allow you to get around 200v peak for 144 volt rms and 212 rms amps per phase. That would give you closer to 92 kw. Would that mean you need a 200 volt battery pack?
