Old 09-08-2010, 12:25 PM   #12 (permalink)
DonR
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
For the hatch ducting I was picturing tubing welded together in an upside down U shape on the sides & top. The tubing would have a slot milled in the trailing edge for the air to exit. Similar to a stalled rear wing.
I might try just sucking the air in from the underside of the car first. Flexible ducting hose from a race supply shop may help facilitate routing to the suction side of the turbo if you want to bring it from the front of the car.
I would put the turbo directly after the cat, for simplicity sake. If it doesn't work out, you can get a pipe made to put the exhaust back to normal.
