Buhahahaha, the jetta is home. I need to either remove or replace calvin on the back window urinating on the words "spark plugs"
Stuck it in 3rd and with a bit of insulation stripped from a hot wire and the starter wire exposed for starting. Got the thing running and drove it home. All I need to do now is wire up some switches, fix the shifter, exterior door handle on passenger side, and come up with a key for the door locks.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
