I do not know if frontal area matters so much with this plan. The reason why is if the car has attached flow till the end of the car then the area that you are trying to fill is only the size of the wake and then you are just trying to push the wake back to remove drag.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
