Old 09-09-2010, 04:46 PM   #74 (permalink)
unixrocks
Originally Posted by orange4boy View Post
All I did with the 14 v hillbilly battery was connect it to the 12V battery leads. Done! The DC-DC is under 0 load until the battery drops to ~13.5. Then it slowly starts sharing the load with the battery so you can never drain it too far. With an anderson connector to avoid reverse polarity accidents, It's totally idiot proof and requires no modifications.
Final thing I am trying to figure out now that I have a 14v battery is whether to run the 12V battery inline with it? Reason being it would be a lot easier to put a quick disconnect on the 14V battery for recharging at night and have the 12V keep the ECU settings intact - honestly I can't see a downside to running the two batts together because the 12V is just going to sit there taking a low current charge from the 14v but maybe I am missing something?
