Old 09-10-2010, 11:41 AM   #9 (permalink)
dmac257
aerobrick - '04 Dodge Dakota Quad Cab SXT
Originally Posted by BamZipPow View Post
Don't be afraid to make yer own frame to make attachment points to. That's what I did fer making my belly pan. Fer my airdam...I just extended the valance down using thread all and sched 40 1/2" pipe.
I am not afraid to make a frame and I realize that I will need to support the under pan to keep it from flapping around. The back of the bottom of the air dam will also need to be supported.
I did a google search for thread all and got lots of sewing thread sites .. is that just threaded rod? got any pictures of your dam? My front bumper angles back about 80 degrees from vertical. Should I make the dam vertical or continue the 80 degrees down to clearance height?
Don
