Old 04-13-2008, 03:28 PM   #49 (permalink)
fabrio.
fabrio.'s Avatar
tigra AERO - '96 opel tigra
ok, ******* work tonight: my hands are destroyed, and I am dirty as a pig but I am happy...
I finished to install total rear extractor, and the I have find how to make a coverage in the transversal axis of rear ARM
He is not a good job because of screws with view, and because the extractor is in two parts of differents materials and small but present difference of geometry.
In future, I will go to make an rear extractor in only one piece, and I will go to apply vertical fins at the ends of him.
start
above, the full view of new work, and below, you can see the coverage of rear arm...for this I am very happy because I am thinking lot time
The central cover is anchored only at the gas tank covers , because the rear arm on the road can muve it up and down, pull down the central cover.
Now, the air flow can to muve with minimum turbulence.
front view of work
still
ended with gray paint
Yesterday I bought the coroplast (2.5x1000x2000mm) for to cover the frame, next day, if I am not problems with job or other, I will go to apply on the car.
Only question: how I cam to anchor he?
thanks for your attention
The Following User Says Thank You to fabrio. For This Useful Post:
Piwoslaw (03-29-2013)
