Can't really help with real world experiance on this but given that 4 stroke engine fires on every other TDC. on standard 4 cylinder a firing is happening at each 180 interval (every time a piston comes up, one of them fires as 2 are up and 2 are down).
Now with only 2 working its going to be very rough running IMO and have real low TQ (hp is not a factor really as you need to get going from a stop) .I think 626 is to heavy for 2 cylinder, maybe 3, I think it be better to just use smaller more efficient 4 cylinder , tuned for long stoke, low rpm .
Whats the weight on 626 , around 2800 Lb ?
engine is 2.0 liters if memory is ok .
