Originally Posted by unixrocks
Final thing I am trying to figure out now that I have a 14v battery is whether to run the 12V battery inline with it? Reason being it would be a lot easier to put a quick disconnect on the 14V battery for recharging at night and have the 12V keep the ECU settings intact - honestly I can't see a downside to running the two batts together because the 12V is just going to sit there taking a low current charge from the 14v but maybe I am missing something?
Uhh ok got my answer today when I tried it....the 12V battery starts charging off the 14V battery but without anything to stop it from charging it just drains the 14V battery while gassing off the excess power.
Not a good idea for either battery.
So....guess I will just use my lawnmower SLA battery to keep the ECU alive while I charge at night - test and see if the mileage improvement is worth the hassle of a cleaner solution.
