Old 09-12-2010, 08:07 AM   #5 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
I have folded the coroplast using heat, with the purpose of doubling the edge for strength and to make it easier to fasten to. I took a metal straight edge, clamped it down along the coroplast at the bend, and ran a propane torch along the bend area, then quickly grabbed the coroplast and bent it. Then flamed the other side a bit to make the coroplast relax and keep the bend.
I think you could make a bump in the middle of the coroplast. Cut a hole in a piece of plywood in the right shape. Set the coroplast on the plywood. Make a plug with rounded edges, smaller than the hole in the plywood, and make it so you can add weight. Put the plug with weight on the coroplast over the hole, and from underneath, start flaming the coroplast. It will probably get wavy and buckle, but I think it would work and would be permanent if you let it cool before removing the plug and weight. You might want to make a stop so that the plug doesn't go all the way through.
Coroplast could probably be vacuum formed, within limits. The corrugation reduces the ability to change the shape, but some changes could be made.
Nissan Versa Aeromods
The Following User Says Thank You to skyl4rk For This Useful Post:
aerohead (05-08-2014)
