Here a link on balancing that may give some info for those not familiar with the process .
Understanding Crankshaft Balancing: Engine Builder
There really not a lot of room around the rod ends on many engines (bottom of cylinder wall come down close to crank so so do the block walls , all to make block strong ) .
Your really going to have tough time removing rod/piston .
