Old 09-14-2010, 03:37 PM   #11 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
I don't think drivers are taking them off just because of looks. If your in a place with a lot of step hills the covers reduce brake cooling and thus braking. I can see these as being of use on the plains but in hilly or mountainous areas they could lead to run away trucks. Braking distance is bad enough on a semi under these conditions they don't want to make it worse.
The Following User Says Thank You to ConnClark For This Useful Post:
Dodge 1996 4x4 Dan (06-26-2023)
