Old 09-15-2010, 11:06 AM   #37 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by 2007 ion2 View Post
like I said, 0W30 is for better cold starts, I do not need to worry about that anymore.
It helps all cold engine starts, not just cold weather starts.
If one lives in a very cold climate, 0W30 may be required because of the low temperatures - but that doesn't mean it can't be used in warmer climates for its fuel economy benefits.
my question is why didn't volvo release a change to the recommended tire pressure for that vehicle?
Dunno.
I originally started running a higher pressure in my 17" wheels to improve handling - based on reports from other users - as steering felt quite mushy, wandering all over the place on.
nitrogen is stable enough to make a difference. I drove my saturn (with a proper nitrogen fill in all 4 tires, from the factory), from -40F weather down to tennessee (I think it was 30F), and didn't see a difference in tire pressure
I'd expect to see a small pressure difference, based on a 33°C / 70°F increase in temperature.
The laws of physics don't change because tyres are filled with another gas.
nitrogen also stays filled longer, leading to less need to check the pressures.
Making people forget about it even more ...
it does this because it has physically larger molecules.
While true, rubber tyres aren't exactly molecular sieves that differentiate between O2 and N2 ...
it will also help protect TMS equipment and alloy rims commonly found on modern cars because of the lack of contaminates.
Is corrosion on the inside if the rim a problem at all ?
It's pretty much a shielded environment.
