Originally Posted by KamperBob
Usually thinner air at elevation leads to richer mixture and less efficient. The rule I recall is a normally aspirated engine loses 2% max power per 1000' elevation. So 6500' should pay a 13% handicap compared to sea level by all rights. Then again, maybe you know something others don't...
Cheers
KB
The engine adjusts gas according to how much air is going in though... not volume but actual mass... right? That's the basis for hot air intakes.
When I had a Grand Cherokee I got much higher gas mileage driving around Montana and Wyoming than Texas.
