Euromodder thanks, good to know there are some 2 cylinder parallel twin out there that are smooth enough for production.
These are both on bikes though so i assume the RPM is higher at idle from a quick search about 1300 rpm so that might help reduce the vibration. Maybe if i go to 2 cylinder i do need to up the idle RPM so the engine doesn't shake itself apart and if i remove 2 cylinders and all their losses and increase the RPM by less than double i will have a fuel saving anyway.
Olympiadis thanks for all the good suggestions, given me a few ideas for when/if i try this out. I am hoping i dont have to change the ECU or get a custom one but will see how i go.
