Old 09-16-2010, 02:36 PM   #129 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by COcyclist View Post
I hope you can arrive at a simpler solution that meets safety requirements and doesn't ruin the lines of your beautiful work. I remember seeing a luxury SUV which has the reflectors as narrow strips in the rear bumper instead of integrated with the taillights. Could you possibly put simple reflectors into rear wheel fairings to indicate true width? If you feel they must be in the tail, you could use a small cutout "frenched" (hot rodder term- used for antennae mounts etc.) into the tail, the air would skip right over them.
If I understand you correctly, my use of the word "embed" I believe is the same as your use of the word "frenched".
There will be a "trench" cutout that is about 2.5 inches high by about 2.5 feet long that will house not only the reflectors, but blinkers/tail lights as well.
The end result will be air flow across the tail piece that is only interrupted by the crack between the acrylic cover and the bodywork, so there should be minimal flow disruption in the area.
Jim.
