Old 09-16-2010, 02:24 PM   #16 (permalink)
Otto
Originally Posted by yepvegas View Post
I would'nt want to put those on my car I like the look of the aluminum ones but I drive to much in the mountains and do not want the brakes to get that hot. I would have to duct air to them and that reduce the affects of the wheel covers. That is my theory anyways.
Probably a good theory, but if the pans are aluminum, and since aluminum is a very efficient heat conductor, maybe the heating problem would be not so bad.
My Porsche has Design 90 wheels, pressure cast with basically a pizza pan outer shape, but with vents at the rims. Cooling of brakes good. On a high speed ratrace through British Columbia some years back, about 30 of us went through rain and mist such that you could clearly see the wake and flow from each car. Despite identical car shape, the type of wheels made a huge difference in apparent air flow, with deep set spoke wheels being about the worst, and Design 90 and so-called "sewer lid" Porsche wheels the best. The deep dish spoked wheels threw out a lateral column of air which surely helped brake cooling, but utterly buggered flow along the sides of cars so equipped.
