Old 09-16-2010, 03:46 PM   #13 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by CapriRacer View Post
First, no one is going to be able to answer your question with any degree of accuracy. To understand why, you need to read this:
Barry's Tire Tech
and this:
Barry's Tire Tech
Is it certain that the different tyres were indeed tested with a different load ?
If I was to study the effects of tyre size, I'd study the effect of all allowed tyre sizes on a given vehicle (i.e. always with the same vehicle weight).
In that light, I'd come to the opposite conclusion - and each and every car manufacturer is complying with that conclusion as they're fitting their eco-models with skinny tyres.
If wider tyres were beneficial, surely they'd all fit those instead of narrower tyres ?
The study also has a graph (p. 35) correlating RR (actual force, not coefficient) to LI, with higher LI also resulting in higher RR.
(83% correlation, and even 86% to max. sidewall load)
Higher LI (and max sidewall load) usually goes together with wider, lower profile tyres.
Same with tyre weight, overall diameter - which both show a 75% correlation with RR - where increasing weight and diameter would usually indicate a wider, lower profile tyre.
All these then result in the graph on page 30, clearly indicating higher RR (actual force) for the wider tyres.
(What I'm missing in the study, is a graph of RR versus profile height.)
In the end, you need to overcome the actual RR force of a tyre at a given load, not a RR coefficient.
The study concludes :
Rolling resistance rolling forces and rolling resistance coefficients did not correlate.
But I fail to see where it comes to the conclussion that wider is better.
