There talking about using a rotating cylinder liner to reduce ring friction at TDC and still use normal valve train .
The issue with this setup is it will take up more space.
The way engines blocks are cast if a rotating cylinder liner enter into design the length of block would go up and this is critical in FWD space (engine + trans ) .
Maybe on trucks and large stationary engines it be ok .
