Old 09-16-2010, 08:40 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I don't know if it matters which injector, I'm hoping not, but don't know why they need separate leads to the ECU.
you want to tap the lead going to the ecu, I believe it will be negative switched. Which means unplug the injectors, turn on the ignition, pick a lead and if it is at 12 volts, tap the other lead.
