If you use a closed system on the heat exchanger side that can hold a vacuum it will reduce the boiling temp, but as pressure rises from the boiling water it will drop the vacuum increasing the boiling temp. So you would need to place a large enough vacuum on it to over come that.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
