I've got the VX ECU, it's single stage and kicks in at 5,000 rpm. I got a JDM engine and did not replace the timing belt, but thanks for the cam setting. I have '95 Civic CX hatchback, I'm not using FE instruments, but my commute has been the same for 10 years so I pretty well know my consumption, I live near Barrie Ontario, Canada, and work at the Toronto airport, around 150kms a day,(90 miles). I put in 5th gear at 80kph and run at around 2,500rpm. By the way do you use less gas to lug 5th gear on hills or change down to 4th?
Thanks for the replies
