Personally i think if you are causing the pollutants to increase by killing then re starting the engine the answer is simple - don't turn off the engine!!
by drop from 2750rpm under load to an idle of 800rpm unloaded will still VASTLY reduce fuel used and gassed produced.
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
