hvatum -
Originally Posted by hvatum
hmmm, I hadn't thought of just getting a used diesel.
There are a few TDIs in my area on Auto-trader.com. I do a lot of my own auto maintenance, so barring major work I feel reasonably confident doing it myself. Otherwise I have a local place that's quite good with VWs.
Now I'm torn between a used Prius at $10,000, and a diesel TDI at the same price. I'm going to investigate the mileage that each one gets in practice, which modifications I can do to each (I'm guessing there's more room for improvement on the Diesel). One plus on the TDI is that it's manual, and would be more fun to drive.
If you opt for the second-gen Prius, there is always the down-the-road option of converting it into a plug-in Prius :
All About Plug-In Hybrids (PHEVs)
http://www.calcars.org/vehicles.html
I know that plug-in options run about $6K+ :
Aftermarket Conversion Sources
http://www.calcars.org/howtoget.html
Advanced Do It Yourself/EAA-PHEV www.priusplus.org: CalCars and the Electric Auto Association's PHEV group created this open-source project to bring PHEV conversions to '04-08 Prius owners across the country. Our goal is to enable owners to enlist a local electrician/engineer to convert their cars, initially with lead-acid batteries, for under $6,000 and two person-weeks of time. (We will have similar solutions available for better (but more expensive) nickel-metal hydride or lithium-ion batteries.) If you're an engineer or an advanced do-it-yourselfer who is comfortable around high voltage batteries and automotive workshops, you can join the discussion and the project!
CarloSW2
