This should keep me busy!
Ultra-Gauge
Potential available gauges include:
•% Engine Load
•Engine Coolant Temperature (ºF)
•Short Term Fuel Trim Bank 1
•Long Term Fuel Trim Bank 1
•Short Term Fuel Trim Bank 2
•Long Term Fuel Trim Bank 2
•Fuel Pressure (PSI)
•Intake Manifold Absolute Pressure (PSI)
•RPM
•MPH
•Timing Advance
•Intake Air Temperature (ºF)
•Mass Air Flow Sensor 1 (g/s)
•Absolute Throttle Position 1 %
•Bank 1 0xygen Sensor 1 Voltage
•Bank 1 0xygen Sensor 2 Voltage
•Bank 1 0xygen Sensor 3 Voltage
•Bank 1 0xygen Sensor 4 Voltage
•Bank 2 0xygen Sensor 1 Voltage
•Bank 2 0xygen Sensor 2 Voltage
•Bank 2 0xygen Sensor 3 Voltage
•Bank 2 0xygen Sensor 4 Voltage
•Run time since last Start (hours:mins)
•Distance traveled with Check Engine Light On.
•Fuel Pressure (Diesel)
•Bank 1 Wide 0xygen Sensor 1 Lambda
•Bank 1 Wide 0xygen Sensor 2 Lambda
•Bank 1 Wide 0xygen Sensor 3 Lambda
•Bank 1 Wide 0xygen Sensor 4 Lambda
•Bank 2 Wide 0xygen Sensor 1 Lambda
•Bank 2 Wide 0xygen Sensor 2 Lambda
•Bank 2 Wide 0xygen Sensor 3 Lambda
•Bank 2 Wide 0xygen Sensor 4 Lambda
•EGR Flow %
•EGR Flow % Error
•Evaporative Purge %
•Fuel Level % of full
•Number of Warm-ups since Check Engine Light Cleared
•Distance traveled since Check Engine Light Cleared
•Evaporative System (PSI)
•Barometric Pressure – Inches of Mercury (inHg)
•Catalytic Converter Bank 1 Sensor 1 Temperature (ºF)
•Catalytic Converter Bank 2 Sensor 1 Temperature (ºF)
•Catalytic Converter Bank 1 Sensor 2 Temperature (ºF)
•Catalytic Converter Bank 2 Sensor 2 Temperature (ºF)
•Battery Voltage
•Relative Throttle Position %
•Outside Ambient Air Temperature (ºF)
•Absolute Throttle Position 2 %
•Accelerator Pedal Position 1 %
•Accelerator Pedal Position 2 %
•Command Throttle Position %
•Engine Oil Temperature (ºF)
•Mass Air Flow Sensor 2 – Calculated
•Instantaneous MPG
•Average MPG – General
•Average MPH – General
•Run Time – General
•Distance – General (miles)
•Fuel Used – General (Gallons)
•Average Gallons/Hour - General
•Fuel Level
•Instantaneous Gallons/hour
•Distance to Empty (miles)
•Time to Empty
•Volumetric Efficiency (MAP vehicles only)
•Average MPH – Trip
•Average MPG – Trip
•Fuel Used – Trip (Gallons)
•Gallons per Hour (GPH) – Trip (Gallons)
•Run Time – Trip (Hours:Minutes)
•Distance -Trip (miles)
•Oil Change Distance (miles)
•Service Distance (miles)
•UltraGauge Internal Temperature (ºF)
*Actual available gauges is vehicle dependent.
Compare this to the
Scangauge
