Thread: Citicar Brakes
Old 09-21-2010, 12:45 PM   #4 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Auto part store can special order the bearing and press it all together, other then that you need to order stuff from EVperformance.com, about $200 in parts to replace the wheel bearing properly on a single side, the ring that holds the wheel bearing in place gets drilled and chiseled off, not pressed off, new retaining ring is about $75, the seal is also a special part that the auto part store does not have.
I spent almost a month trying to find parts including a number of golf cart shops around here.
