Old 09-21-2010, 05:51 PM   #24 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by ShadeTreeMech View Post
Higher boost would raise the egt, especially if not accompanied with increased fuel injection. I'm no expert, so correct me if I'm wrong.
I do know higher EGTs spell death for a diesel engine, so it's best to avoid that scenario.
Higher boost lowers EGTs when not accompanied with increased fuel. The reason is that there is more air to heat in the cylinder with the same amount of fuel. Note that a diesel doesn't get hot when running lean like a gas engine.
