Just a thought regarding the scope. Back in the day i used to use a crystal earphone to "scope" circuits. As long as the signal is audible it works great. Use a small resistor for dc coupling and a .1uf cap for ac.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
