Old 09-22-2010, 10:23 AM   #24 (permalink)
redyaris
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
redpoint5 It sounds like the track you ride/race on has relatively short strats, so you can't get into 6th gear. You may still benifit on the track from a larger front sprocket if the track has slow corners on which you can't apply full throatle on the exit of a turn. You mit want to experament at the track with a bigger front sprocket to see how it affects your lap times. You could find that for some tracks the taller gearing reduces lap time...!
