Ever tried to change the thermostat on a Imp?? I had one back in the 70's, great little car but the gear change was a bit iffy. It got to the stage where I could pull the engine out in no time flat, just pulled it out of the back of the car. Also make sure the timing chain is in good nick or you could up up with more bent valves than you could shake a stick at.
Good luck, Neddy.
