Old 09-22-2010, 11:37 PM   #3787 (permalink)
The Toecutter
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
When should the control board gate driver output be connected?
Does the control board have to be connected to the power board in order to test if the control board is working properly?
Also, on the pdf file showing the assembly process, you never specify where the ground wires from PH1 to PH2 go to. Do those need to be connected to the ground on the ground on the power board before testing can be done?
I'm interested in purchasing one of these myself, and upgrading it to match the high voltage capabilities of my motor. Also, how is current limiting done with this device? Is it programmable by chance?
