The overcurrent circuit monitors only motor amps, but battery amps are motor amps times pwm duty.
No higher voltage issues with the control board that I am aware of. The only possible issue I can think of is the separation distance between the power ground and control ground. I don't think that will be a problem though. There's nothing like actually trying it.
Let's see, good phone times are in the afternoon after work. Like after 3 or so. We sometimes are out of the house to Costco to get pizza or something.
