Old 09-23-2010, 02:16 PM   #6 (permalink)
cmj
Honda - '96 Honda Civic EX
90 day: 36.12 mpg (US)
HIGH COMPRESSION. Especially with those sleeves you will be able to raise compression greatly. Just make sure you have adequate tuning. The only problem I see with high compression is if you employ P&G is the amount of energy you will lose turning the engine over (IF you bump start it)
