...Counter Electro-Motive Force (CEMF) -- it does not matter *how* a wire is moved through a magnetic field (motor = pulled through the field; generator = pushed through the field), only that wire-through-field movement occurs.
...CEMF is *how* regeneration-charging occurs during braking.
