Through hole is still best if this is headed for a Kit, especially if you are close to a working thing already. I actually did my first smd on an obddiag kit the other day, pain in the butt with "regular" equipment. Any chance this will work with my mars brushless (hall effect PM jobbie)?
Is the fine resolution speed sensor there so you can detect slippage quickly and bump up the "field" power if it has dropped to much?
