Old 09-24-2010, 01:51 AM   #376 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
I still don't really understand it. haha. It sort of makes me happy though. I think once the controller is working, and I see lots of I_torque, I_field, and who knows what all graphed out, it will make a lot of sense.
I LOVE that new oscilloscope! Holy cow! I just put that sucker on each of the 6 pwm outputs, and it made debugging a million times easier!!!!!!!!!!!!!!!
I added a pretty strong (1kOhm) pulldown resistor to the power supply of the 6 HCPL-4506 optocouplers. Now, when I create an artificial overcurrent event, all 6 pwm outputs disable! Before, the power supply was left floating, sort of disconnected from the 5v supply by turning off a p-channel mosfet. The problem was, it was floating at around 2v, which was enough to turn on some of the optocouplers, since some have a better current transfer ratio than others.
So, I think the whole stinking thing works now! I really should check to see that the 6 undervoltage circuits are working. I have every reason to believe that they are.
I could NOT have done this without that oscilloscope. The motor WILL turn by Sunday... That's the rules. I didn't write them.
This is the first time I've ever made a circuit that only had 1 thing wrong with it. hahaha. 1 resistor out of like 290 components or so.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
mpgmike (01-26-2022)
