your % load has more things in it than just the TPS. That has a very direct effect, but RPMs make a significant difference. I am guessing that is what you mean by all the numbers with no values or corresponding assigned descriptor. If you want to have a lower load, OR HIGHER, you need to change more than just your TP or RPM's as the torque curve of the engine plays a major role in the %load you will need to use at different speeds.
