Originally Posted by Patrick
Propane tanks are very low pressure in comparison. You just need enough pressure on the propane for it to change state into a liquid (about 150 psi @ 90F).
Yep... Propane gas (top of the tank) is always at the vapor pressure which is a function of temperature but pretty low even on hot days.
