Originally Posted by Weather Spotter
Welcome to the fourm!
I would start with 40-44PSI or max sidewall if they are lower than that.
Thanks!
So I should go over the max stated on the front tires (35)?
Can I set the tires at different pressures (higher for the back, lower for the front)?
Also, is the max sidewall different from the max PSI listed on the tire?
