Old 09-27-2010, 12:22 AM   #5 (permalink)
acropora1981
Jet - '99 Suzuki Swift Hatchback
Originally Posted by Weather Spotter View Post
What tire has a max side wall of only 35PSI? You can go higher but you run risks of handling issues, and tire wear. Try it and see if it helps. If the back is rated for higher I would try them all at 40PSI.
The fronts are rated at 35. I'll try them all at 35 first, and then try to bring them up too around 40.
