Old 09-27-2010, 03:28 AM   #6 (permalink)
briogio
Just did the swap
Well as I've painfully found out, you have to have the right exhaust manifold with 5 wire O2 sensor,(expensive!), an EGR valve with accompanying soleniod, wiring, and box thing with some other bit, not forgetting the P07 ECU all wired up into existing harness. So it's not simple and it's certainly not cheap
